hi, I have a problem… about jetson nano.
When I use yolov3-tiny, the power goes out.
The power adapter is 5V/2A.
What should I do??
What should I do??
Hi hastar0409,
It could be the USB cable of the USB adapter, sometimes these are not very reliable.
If have a compatible DC barrel jack power supply, I would go ahead and try that to see if there is any difference in behavior.
2a is not enough for the nano in “turbo” mode
Switch to 10w and try again. You need at least 3a.
Thanks all
I didn’t know I had to use J48 pins to use DC power.
now jetson nano works well!
