I was able to successfully power-up Nano with the micro USB and even install stuff on it, but when I tried to power it with the barrel jack (yes, I had shorted the J48 pins with a jumper), I saw is no sign of life on the board. I am using an adjustable desktop power supply (5A max) still wasn’t able to get it working.
I couldn’t find C308, but I measured the voltage across C315 to be only around 1.42 V :(. I did measure the output across the female jack, which was 5V. I guess the DC/DC convertor is to be blamed for the problem.
The only way I power it up (for highest performance) is by using the expansion headers, which is a bit inconvenient. I would really like it to be powered by a DC barrel jack.
Do you know if it is possible to replace the board if its a manufacturing defect? It’s been a week since it arrived. I had ordered it from the Nvidia website.
