Jetson Nano USB provides no power
Hello community,
I‘ve recently assembled my Yahboom Jetbot mini with the Nvidia Jetson Nano board. The robot kit comes with a wifi card that is powered by USB. The card is working fine when tested with a PC, however it does not get any power when plugged into any of the board‘s USB ports. The control light of the board is on.
Has anyone had a similar problem or might this be an issue with the board itself?
Thanks a lot!
Suggest to check Issues · NVIDIA-AI-IOT/jetbot · GitHub to see if can find some similar cases.
