1.I download cuda10.2 (cudnn8.0) form jetpack
[图片]But wen I install the cuda
have a mistake
root@be28b43454e2:/home/NX_environment/sdkm_downloads# dpkg -i libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb
(Reading database … 27245 files and directories currently installed.)
Preparing to unpack libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb …
Unpacking libcudnn8 (8.0.0.180-1+cuda10.2) …
dpkg: error processing archive libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb (–install):
unable to make backup link of ‘./usr/lib/aarch64-linux-gnu/libcudnn.so.8.0.0’ before installing new version: Invalid cross-device link
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Processing triggers for libc-bin (2.27-3ubuntu1.4) …
Errors were encountered while processing:
2. Through these DEB packages, what commands should I use to install cuda10 2 and cudnn8 0
3.
At the same time, I also want to install tensorrt. What files do I need? Where can I download them
The most important thing is that I use jetson- NX
