I have a Jetson AGX Orin Developer Kit (32GB).
Can I use the AGX Orin 64GB module with the 32GB Developer Kit?
I don’t want to buy the 64GB Developer Kit.
Yes, that’s compatible.
Thank you for your reply. I unscrewed the developer kit.
The module is attached to the fan and heatsink with glue, and it seems difficult to replace it.
Is it really possible? Do you have a manual?
No manual for this. The carrier board is same, the module can be swapped if necessary.
