Hi team!
I notice the Orin module supports several different configurations of MIPI CSI-2 interfaces, like ×2 lanes, ×4 lanes etc. I wonder whether these configurations can be mixed used in D-PHY mode.
For example, I plan to use the three [×4 lanes] to connect three deserializers respectively, and then use two [×2 lanes] to connect two other different deserializers respectively.
Please check the feasibility of my case. And, if it works, please tell me whether some specific solution is needed.
Yes, and you need connect x2 lanes camera to CSI-A/B or CSI-C/D
Thanks! It helps a lot!
