hi nvidia:
does jetson orin csi support CSI-2 extended virtual channels ?
jp6.2.2
hi nvidia:
jp6.2.2
The question is about the NVIDIA Jetson AGX Orin’s support for CSI2 extended virtual channels, specifically JP622.
Unfortunately, the provided context does not explicitly mention the Jetson AGX Orin’s support for CSI2 extended virtual channels or JP622. However, I can provide some general information about the Jetson AGX Orin’s CSI interface and compare it with other NVIDIA Jetson modules.
The NVIDIA Jetson AGX Orin is a high-performance AI computer module that features a CSI-2 interface for camera connectivity. CSI-2 (Camera Serial Interface 2) is a standard interface for camera modules, and it supports multiple virtual channels for transmitting data from multiple cameras.
While the provided context does not specifically mention the Jetson AGX Orin’s support for CSI2 extended virtual channels or JP622, it’s worth noting that the Jetson AGX Orin’s CSI interface is likely to support multiple virtual channels, including extended virtual channels.
In comparison, the NVIDIA Jetson AGX Xavier module, which is a predecessor to the Jetson AGX Orin, supports up to 6 virtual channels on its CSI-2 interface. However, the specific support for CSI2 extended virtual channels or JP622 is not mentioned in the provided context.
To provide a more accurate answer, I would recommend checking the NVIDIA Jetson AGX Orin’s documentation or contacting NVIDIA support directly to inquire about the specific support for CSI2 extended virtual channels or JP622.
In summary, while the provided context does not explicitly mention the Jetson AGX Orin’s support for CSI2 extended virtual channels or JP622, it’s likely that the module supports multiple virtual channels on its CSI-2 interface. However, further clarification is needed to provide a more accurate answer.
Suppose AGX serial devices have no problem to support virtual channel.
hi nvidia:
I set vc-id = <7>; in dts
and enable extended virtual channels in max96712 side, but can not work
and I saw orin nx can not set vc-id greater than 3, so agx orin is same ? Can the vc-id of the device be set to greater than 3? - Jetson Systems / Jetson Orin NX - NVIDIA Developer Forums
Right current support 4 virtual channel each CSI port.
Ok, Thanks
