Hi Experts,
I develop the max9295 + max9296 +imx390 camera driver with jetson agx orin.
The command as show:
gst-launch-1.0 v4l2src device=/dev/video6 ! videoconvert ! xvimagesink sync=false
12 vi-output, imx3-2618 [005] .... 291.170467: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 10
13 kworker/2:3-227 [002] .... 291.182049: rtcpu_vinotify_event: tstamp:9923230201 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:317542998848 data:0x399d580010000000
14 kworker/2:3-227 [002] .... 291.182052: rtcpu_vinotify_event: tstamp:9923230337 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:317543041536 data:0x0000000031000001
15 kworker/2:3-227 [002] .... 291.182052: rtcpu_vinotify_event: tstamp:9923230493 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:317543059200 data:0x399d550010000000
16 kworker/2:3-227 [002] .... 291.182052: rtcpu_vinotify_event: tstamp:9923230625 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:317543119552 data:0x0000000031000002
17 vi-output, imx3-2618 [002] .... 293.984125: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 10
18 kworker/2:3-227 [002] .... 294.046001: rtcpu_vinotify_event: tstamp:10011664913 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:320356691520 data:0x399d580010000000
19 kworker/2:3-227 [002] .... 294.046003: rtcpu_vinotify_event: tstamp:10011665093 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:320356734208 data:0x0000000031000001
20 kworker/2:3-227 [002] .... 294.046003: rtcpu_vinotify_event: tstamp:10011665250 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:320356751840 data:0x399d550010000000
21 kworker/2:3-227 [002] .... 294.046004: rtcpu_vinotify_event: tstamp:10011665385 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:320356812224 data:0x0000000031000002
22 vi-output, imx3-2618 [002] .... 296.798420: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 10
23 kworker/2:3-227 [002] .... 296.869947: rtcpu_vinotify_event: tstamp:10099556006 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:323170956960 data:0x399d580010000000
24 kworker/2:3-227 [002] .... 296.869950: rtcpu_vinotify_event: tstamp:10099556148 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:323170999648 data:0x0000000031000001
25 kworker/2:3-227 [002] .... 296.869950: rtcpu_vinotify_event: tstamp:10099556304 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:323171017312 data:0x399d550010000000
26 kworker/2:3-227 [002] .... 296.869951: rtcpu_vinotify_event: tstamp:10099556439 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:323171077664 data:0x0000000031000002
27 vi-output, imx3-2618 [002] .... 299.614424: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 10
28 kworker/2:3-227 [002] .... 299.637898: rtcpu_vinotify_event: tstamp:10187100372 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:325987005056 data:0x399d580010000000
29 kworker/2:3-227 [002] .... 299.637900: rtcpu_vinotify_event: tstamp:10187100512 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:325987047712 data:0x0000000031000001
30 kworker/2:3-227 [002] .... 299.637900: rtcpu_vinotify_event: tstamp:10187100670 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:325987065280 data:0x399d550010000000
31 kworker/2:3-227 [002] .... 299.637900: rtcpu_vinotify_event: tstamp:10187100805 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:325987125632 data:0x0000000031000002
32 vi-output, imx3-2618 [002] .... 302.430497: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 10
33 kworker/2:3-227 [002] .... 302.453862: rtcpu_vinotify_event: tstamp:10275121635 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:328803061696 data:0x399d580010000000
34 kworker/2:3-227 [002] .... 302.453863: rtcpu_vinotify_event: tstamp:10275121775 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:328803104384 data:0x0000000031000001
35 kworker/2:3-227 [002] .... 302.453863: rtcpu_vinotify_event: tstamp:10275121933 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:328803121984 data:0x399d550010000000
36 kworker/2:3-227 [002] .... 302.453864: rtcpu_vinotify_event: tstamp:10275122068 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:328803182368 data:0x0000000031000002
Note: imx390@28 bind to /dev/video6
DTSI:
tegra234-camera-imx390-a00.dtsi.txt (46.3 KB)
tegra234-p3737-0000-camera-imx390-a00.dtsi.txt (6.3 KB)
tegra234-p3737-camera-modules.dtsi.txt (9.9 KB)
Trace:
trace.txt (4.5 KB)
kernel:
kernel.txt (7.3 KB)
I refer to the forum URL as show:
I change as show:
1375 ++deskew_initial_enable = “true”;
1376 serdes_pix_clk_hz = “200000000”;
imax390@28 mode as show:
1331 mode0 {/*mode IMX390_MODE_1920X1080_CROP_30FPS*/
1332 mclk_khz = "24000";
1333 num_lanes = "2";
1334 tegra_sinterface = "serial_a";
1335 vc_id = "1";
1336 discontinuous_clk = "no";
1337 dpcm_enable = "false";
1338 cil_settletime = "0";
1339 dynamic_pixel_bit_depth = "16";
1340 csi_pixel_bit_depth = "16";
1341 mode_type = "yuv";
1342 pixel_phase = "yuyv";
1343
1344 active_w = "1920";
1345 active_h = "1080";
1346 readout_orientation = "0";
1347 line_length = "2200";
1348 inherent_gain = "1";
1349
1350 pix_clk_hz = "74250000";
1351 deskew_initial_enable = "true";
1352 serdes_pix_clk_hz = "200000000";
1353
1354 gain_factor = "10";
1355 min_gain_val = "0"; /* dB */
1356 max_gain_val = "300"; /* dB */
1357 step_gain_val = "3"; /* 0.3 */
1358 default_gain = "0";
1359 min_hdr_ratio = "1";
1360 max_hdr_ratio = "1";
1361 framerate_factor = "1000000";
1362 min_framerate = "30000000";
1363 max_framerate = "30000000";
1364 step_framerate = "1";
1365 default_framerate = "30000000";
1366 exposure_factor = "1000000";
1367 min_exp_time = "59"; /*us, 2 lines*/
1368 max_exp_time = "33333";
1369 step_exp_time = "1";
1370 default_exp_time = "33333";/* us */
1371 embedded_metadata_height = "0";
1372 };
Now the camera imx390 exist the green screen after the test. pls help me,thanks!
