I connected my camera to the usb 3.0 port of the jetson orin nano with a usb 3.0 data cable, but the device still connects to usb 2.0. Please help me
It appears that you are trying to connect a camera to the Jetson Orin Nano, but it’s connecting to USB 2.0 instead of USB 3.0.
Firstly, let’s clarify that the Jetson Orin Nano has two camera connectors, J21 and J22, which are 22-position flex connectors with a 0.5 mm pitch. These connectors are specifically designed for camera modules and do not use USB cables.
The USB 3.0 port you’re referring to is likely one of the USB ports on the Jetson Orin Nano carrier board, which is not designed for camera connections. The USB ports on the carrier board are intended for connecting peripherals such as keyboards, mice, and storage devices.
To connect your camera to the Jetson Orin Nano, you should use the camera connectors (J21 or J22) and a compatible camera module. The camera connector pinout is described in the Jetson Orin Nano Product Design Guide.
If you’re using a USB camera, you should connect it to one of the USB ports on the carrier board, but you won’t be able to use the USB 3.0 port specifically for camera connections.
In your case, since you’ve connected the camera to the USB 3.0 port with a USB 3.0 data cable, but it’s still connecting to USB 2.0, it’s likely that the camera module or the cable is not compatible with USB 3.0, or the USB 3.0 port on the carrier board is not functioning correctly.
To resolve this issue, you can try the following:
- Check the camera module’s specifications to ensure it supports USB 3.0.
- Verify that the USB 3.0 port on the carrier board is functioning correctly.
- Try using a different USB 3.0 cable or a different USB port on the carrier board.
- If you’re using a USB camera, try connecting it to a different USB port on the carrier board.
If none of these solutions work, it’s possible that there’s a hardware issue with the Jetson Orin Nano or the camera module, and you may need to contact NVIDIA support for further assistance.
The camera is a model that can be connected to usb to c and supports 3.0. I’ve tried other ports and other cables.
Do you use developer kit or custom board? If it is custom board, you would need to perform compliance test to ensure signal quality is good.
I’m using a custom board released by holybro. What does conformity test mean?
Please check the guidance for performing compliance test:
Jetson Download Center | NVIDIA Developer
