Jetson Orin Nano Developer Kit – Flashing Failure and Suspected Hardware Issue
Dear NVIDIA Support Team,
I am writing to report a critical issue I am experiencing with my Jetson Orin Nano Developer Kit, which I am unable to resolve despite extensive troubleshooting.
Issue Description:
I am consistently encountering a “Flash Jetson Linux - flash error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.” error during the JetPack flashing process using SDK Manager. This error occurs reliably at approximately 90% completion.
System Details:
Jetson Device: Jetson Orin Nano Developer Kit (8GB)
Host PC OS: Ubuntu 22.04 LTS
SDK Manager Version: SDK Manager 2.3.0.12617 x86_64
Target JetPack Version: 6.2.1
Storage Device Attempted:
Original: 2TB NVMe SSD
Attempted with: MicroSD Card (for diagnostic purposes)
Steps Taken:
I have performed the following comprehensive troubleshooting steps:
  • Initial Attempt: Flashed with SDK Manager to 2TB NVMe SSD. Result: “backup GPT table corrupt” error.
    NVMe Wipe (Standard): Removed NVMe, connected to host PC, used gparted (or fdisk/parted) to create a new GPT. Result: Same error persisted.
  • NVMe Wipe (Aggressive Zero-Fill): Removed NVMe, connected to host PC, performed a full dd if=/dev/zero zero-fill on the entire 2TB NVMe SSD to clear all data and partition tables, followed by creating a new GPT label with parted. Result: Same error persisted.
  • SD Card Flashing Attempt: As a diagnostic step, I attempted to flash the Jetson OS to a good quality microSD card using SDK Manager. Result: The exact same “backup GPT table corrupt” error persisted, indicating the issue is not specific to the NVMe SSD.
  • USB Cable & Port Changes: I have tried multiple high-quality USB-C data cables and different USB ports on my host PC to rule out connection issues. Result: Same error persisted.
  • Host PC Environment: Ensured ample disk space on host, restarted host PC, confirmed stable power to Jetson.
Given that the error persists consistently across different storage types and after exhaustive troubleshooting of the host environment and cabling, I strongly suspect a hardware fault with the Jetson Orin Nano Developer Kit itself, specifically related to its internal flashing mechanism or the M.2/PCIe interface during the flashing process.
I attached logs and screenshots for further analysis if applicable
Could you please advise on the next steps, including potential RMA procedures, to resolve this issue?
SDKM_logs_2025-07-20_17-31-18.zip (4.2 MB)
The issue you’re experiencing with the Jetson Orin Nano Developer Kit, specifically the “backup GPT table is corrupt” error during the flashing process, suggests a potential problem with the device’s internal flashing mechanism or the M.2 PCIe interface. Given the extensive troubleshooting steps you’ve taken, including attempting to flash the device with a microSD card, changing USB cables and ports, and ensuring the host PC environment is stable, it’s reasonable to suspect a hardware fault.
To address this issue, I’ll provide a comprehensive overview of the potential causes and next steps, comparing your situation with similar issues and solutions.
  1. Hardware Fault: The consistent error across different storage types (NVMe SSD and microSD card) and after thorough troubleshooting of the host environment and cabling points towards a hardware issue with the Jetson Orin Nano Developer Kit. This could be related to the device’s internal flashing mechanism or the M.2 PCIe interface.
  2. Comparison with Similar Issues: The “backup GPT table is corrupt” error is not uncommon in flashing processes, especially when dealing with NVMe SSDs. However, the persistence of this error even after attempting to flash the device with a microSD card, which bypasses the NVMe interface, suggests that the issue might not be solely related to the storage device or its interface.
  3. Troubleshooting Steps: You’ve already performed a range of troubleshooting steps, including:
    • NVMe Wipe: Both standard and aggressive (using dd command for zero-fill) methods were attempted to rule out issues with the NVMe SSD.
    • SD Card Flashing: Attempting to flash the Jetson OS to a microSD card to diagnose if the issue is specific to the NVMe SSD.
    • USB Cable & Port Changes: To rule out connection issues.
    • Host PC Environment Checks: Ensuring ample disk space, restarting the host PC, and confirming stable power to the Jetson device.
  4. Next Steps:
    • Contact NVIDIA Support: Given the suspicion of a hardware fault, the next step would be to contact NVIDIA’s support team. They can provide guidance on potential RMA (Return Merchandise Authorization) procedures if the device is deemed faulty.
    • Provide Detailed Logs and Screenshots: You’ve already attached logs and screenshots, which will be helpful for NVIDIA’s support team to analyze the issue further.
    • Consider Alternative Flashing Methods: If possible, exploring alternative flashing methods or tools might provide additional insights or workarounds.
  5. Comparison with Documentation and Community Feedback:
    • The Jetson Orin Nano Developer Kit’s documentation and community forums should be consulted for any known issues or workarounds related to flashing errors.
    • Checking for any firmware or software updates that might address the issue is also advisable.
In conclusion, while the exact cause of the “backup GPT table is corrupt” error during the flashing process of your Jetson Orin Nano Developer Kit remains to be definitively determined, the persistence of the issue across various troubleshooting steps suggests a potential hardware fault. Engaging with NVIDIA’s support team, providing detailed logs and screenshots, and exploring alternative flashing methods or updates are the recommended next steps.
I provided all logs and screenshot for your review. I will wait for a human answer because I already did all the steps suggested by the automatic agent.
I already provided logs but I have not received any human answer yet
The message backup GPT table corrupt could just be a harmless log.
Were you able to access the system after the SDK Manager finished flash?
Yes I could but it is not normal to receive this message from different devices. I can understand from one type of media but from different types of media? (sd card, NVMe). It doesn’t make sense.
I mean, it was not one time. It is each time
Hi @DavidDDD,
Any update about my comment? I bought this card and I have the expectation that it will work without troubles.
Kind regards,
Marlon
Yes it is but I did not receive any proper answer to explain the issue.
Sorry for the late reply. As I mentioned earlier, this is a harmless error,
and our development team is already working on it.
For now, you can simply ignore it.
If you experience a flashing failure, which cannot boot into the system ,please open a new topic and let us know.
Thank you for your understanding.
