Jetson Orin Nano Flash Complete boot issue “ OTA work directory is not found on internal and external storage devices”
使用命令行脚本执行OrinNano烧录 [Jetpack6.2]Super版本系统到SSD硬盘,可以烧录成功,但是启动后调试日志输出如下报错
boot fail.log (107.0 KB)
flash success.log (333.9 KB)
Failed to mount /dev/mmcblkO on the /mnt
Failed to run “mount ota work partition /dev/mmcblk0 /mnt”
0TA work directory is not found on internal and external storage devicesbash: cannot set terminal process group (-1): Inappropriate loctl for devicebash: no job control in this shel!
請問是怎麼準備bsp 和 rootfs.
可以提供步驟以及commands嗎?
謝謝
创建文件夹
sudo mkdir orin_nano cd orin_nano
下载BSP和文件系统包
wget https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v4.3/release/Jetson_Linux_r36.4.3_aarch64.tbz2
wget https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v4.3/release/Tegra_Linux_Sample-Root-Filesystem_r36.4.3_aarch64.tbz2
解压编译
sudo tar xf Jetson_Linux_r36.4.3_aarch64.tbz2
sudo tar xpf Tegra_Linux_Sample-Root-Filesystem_r36.4.3_aarch64.tbz2 -C Linux_for_Tegra/rootfs/
cd Linux_for_Tegra/
sudo ./tools/l4t_flash_prerequisites.sh
sudo ./apply_binaries.sh
设置账户密码
sudo ./tools/l4t_create_default_user.sh -u jetson -p jetson1 -a
烧录
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p “-c ./bootloader/generic/cfg/flash_t234_qspi.xml” -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit-super external
可不可以嘗試將
改成
mkdir orin_nano
有些package可能因為permission關係所以沒有寫入.
謝謝
不使用sudo命令,异常情况还是一样,提示烧录成功重启后提示OTA work directory is not found
详情请查看启动日志。
boot_fail.txt (108.4 KB)
~0507
請問你給的log是一燒完馬上就抓的
還是你已經放著給它跑了一陣子之後才抓的?
[2025-03-26 09:25:04] …L4TLauncher: Attempting Recovery Boot
因為你的log已經卡在recovery boot. 代表前面應該已有幾次開機"normal boot"失敗的情況.
你最一開始3/19分享的log是有normal boot的log. 但現在最新這份沒有給
