Jetson Orin Nano & Flir Blackfly S Spinview Flickering
Running Spinview on Jetson Orin Nano Developer Kit with Flir Blackfly S camera connected via USB results in a flickering preview image. Flickering only present when using continuous capture mode. The camera is still picking up images, but Spinview is just showing continuous flickering. Camera and Spinview works fine plugging into a different laptop using the same cable. Any help would be appreciated!
Video:
Screencast from 02-09-2024 12:46:54 PM.zip (377.1 KB)
  1. Please check kernel message if any error message.
  2. Try boost the clocks to verify.
  3. Try others APP.
sudo jetson_clocks
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
