Jetson orin nano p3767-0003 flash failed
hi ,
I failed to flash the Jetpack5.1.2 using either the SDK Manager or manually. The error message was as follows.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --external-device nvme0n1p1   -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml"   --showlogs --network usb0 jetson-orin-nano-devkit internal
/home/qz/wuhj_develop/nvidia/orin_nx_35.4.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 3-1.3 --device-instance 0 --flash-only --external-device nvme0n1p1 -c "tools/kernel_flash/flash_l4t_external.xml" --network usb0 jetson-orin-nano-devkit internal
*  Step 1: Build the flashing environment    *
Create flash environment 0
/home/qz/wuhj_develop/nvidia/orin_nx_35.4.1/Linux_for_Tegra/bootloader /home/qz/wuhj_develop/nvidia/orin_nx_35.4.1/Linux_for_Tegra
Finish creating flash environment 0.
*  Step 2: Boot the device with flash initrd image *
/home/qz/wuhj_develop/nvidia/orin_nx_35.4.1/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/qz/wuhj_develop/nvidia/orin_nx_35.4.1/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --bldtb tegra234-p3767-0003-p3768-0000-a0.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3767-0003-p3768-0000-a0.dtb"    --secondary_gpt_backup  --bct_backup  --instance 3-1.3
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
 Entering RCM boot
[   0.0383 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0383 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0383 ] rcm boot with presigned binaries
[   0.0393 ] tegrarcm_v2 --instance 3-1.3 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0402 ] BR_CID: 0x80012344705E015F2000000007FF0040
[   0.0489 ] Sending bct_br
[   0.0560 ] Sending mb1
[   0.0564 ] Sending psc_bl1
[   0.0657 ] Sending bct_mb1
[   0.0715 ] Generating blob for T23x
[   0.0733 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.0742 ] The number of images in blob is 18
[   0.0745 ] blobsize is 73374490
[   0.0746 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 2924608
[   0.1039 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[   0.1046 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[   0.1048 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[   0.1050 ] Not supported type: mb2_applet
[   0.1051 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 438768
[   0.1053 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   0.1056 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[   0.1102 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.1119 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1051136
[   0.1125 ] Added binary blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt of size 110080
[   0.1128 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[   0.1130 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[   0.1133 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400864
[   0.1135 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.1136 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1127568
[   0.1139 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.1141 ] Added binary blob_boot0.img of size 55588864
[   0.1439 ] Added binary blob_tegra234-p3767-0003-p3768-0000-a0.dtb of size 347610
[   0.2266 ] tegrarcm_v2 --instance 3-1.3 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   0.2275 ] BL: version 1.2.0.0-t234-54845784-562369e5 last_boot_error: 0
[   0.3137 ] Sending bct_mem
[   0.3214 ] Sending blob
[   0.4063 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --instance 3-1.3 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Cleaning up...
debug uart log
[0055.422] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0055.428] I> t234-A01-1-Silicon (0x12347) Prod
[0055.432] I> Boot-mode : Coldboot
[0055.435] I> Entry timestamp: 0x00000000
[0055.439] I> last_boot_error: 0x0
[0055.442] I> BR-BCT: preprod_dev_sign: 0
[0055.446] I> rst_source: 0x0, rst_level: 0x0
[0055.450] I> Task: SE error check
[0055.453] I> Task: Bootchain select WAR set
[0055.457] I> Task: Enable SLCG
[0055.460] I> Task: CRC check
[0055.463] I> Task: Initialize MB2 params
[0055.467] I> MB2-params @ 0x40060000
[0055.471] I> Task: Crypto init
[0055.474] I> Task: Perform MB1 KAT tests
[0055.478] I> Task: NVRNG health check
[0055.481] I> NVRNG: Health check success
[0055.485] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0055.491] I> Task: Enabling and initialization of Bandwidth limiter
[0055.497] I> No request to configure MBWT settings for any PC!
[0055.503] I> Task: Secure debug controls
[0055.506] I> Task: strap war set
[0055.510] I> Task: Initialize SOC Therm
[0055.513] I> Task: Program NV master stream id
[0055.518] I> Task: Verify boot mode
[0055.523] I> Task: Alias fuses
[0055.527] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0055.534] I> Task: Print SKU type
[0055.537] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0055.542] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0055.547] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0055.551] I> FUSE_OPT_DLA_DISABLE = 0x00000003
[0055.555] I> FUSE_OPT_PVA_DISABLE = 0x00000001
[0055.559] I> FUSE_OPT_NVENC_DISABLE = 0x00000001
[0055.564] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0055.568] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0055.573] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0055.577] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0055.581] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0055.585] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0055.589] I> FUSE_SKU_INFO_0 = 0xd5
[0055.593] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0055.597] I> FUSE_PACKAGE_INFO_0 = 0x2
[0055.600] I> SKU: Prod
[0055.603] I> Task: Boost clocks
[0055.606] I> Initializing PLLC2 for AXI_CBB.
[0055.610] I> AXI_CBB : src = 35, divisor = 0
[0055.614] I> Task: Voltage monitor
[0055.617] I> VMON: Vmon re-calibration and fine tuning done
[0055.623] I> Task: UPHY init
[0055.628] I> HSIO UPHY init done
[0055.631] W> Skipping GBE UPHY config
[0055.634] I> Task: Boot device init
[0055.637] I> Boot_device: RCM
[0055.640] I> USB configuration success
[0056.341] I> Task: TSC init
[0056.344] I> Task: Load membct
[0056.347] I> RAM_CODE 0x4000031
[0056.350] I> Loading MEMBCT
[0056.353] I> Slot: 0
[0056.355] I> Binary[0] block-0 (partition size: 0x40000)
[0056.360] I> Binary name: MEM-BCT-0
[0056.363] I> Size of crypto header is 8192
[0056.367] I> Size of crypto header is 8192
[0056.371] I> BCH of MEM-BCT-0 read from storage
[0056.376] I> BCH address is : 0x40050000
[0056.380] I> MEM-BCT-0 header integrity check is success
[0056.385] I> Binary magic in BCH component 0 is MEM0
[0056.390] I> component binary type is 0
[0056.395] I> MEM-BCT-0 binary is read from storage
[0056.400] I> MEM-BCT-0 binary integrity check is success
[0056.405] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0056.411] I> RAM_CODE 0x4000031
[0056.417] I> RAM_CODE 0x4000031
[0056.421] I> Task: Load Page retirement list
[0056.425] I> Task: SDRAM params override
[0056.429] I> Task: Save mem-bct info
[0056.432] I> Task: Carveout allocate
[0056.435] I> Update CCPLEX IST carveout from MB1-BCT
[0056.440] I> ECC region[0]: Start:0x0, End:0x0
[0056.445] I> ECC region[1]: Start:0x0, End:0x0
[0056.449] I> ECC region[2]: Start:0x0, End:0x0
[0056.453] I> ECC region[3]: Start:0x0, End:0x0
[0056.457] I> ECC region[4]: Start:0x0, End:0x0
[0056.462] I> Non-ECC region[0]: Start:0x80000000, End:0x80000000
[0056.468] I> Non-ECC region[1]: Start:0x0, End:0x0
[0056.472] I> Non-ECC region[2]: Start:0x0, End:0x0
[0056.477] I> Non-ECC region[3]: Start:0x0, End:0x0
[0056.481] I> Non-ECC region[4]: Start:0x0, End:0x0
[0056.493] E> BL_CARVEOUT: Failed to allocate memory of size 0x4000000 for CO:43.
[0056.500] C> Task 0x20 failed (err: 0x49490303)
[0056.504] E> Top caller module: BL_CARVEOUT, error module: BL_CARVEOUT, reason: 0x03, aux_info: 0x03
[0056.513] C> Boot Info Table status dump :
01111111001110001111111111111111
Based on the provided context, it appears that you are trying to flash JetPack 5.1.2 on a Jetson Orin Nano device, but you are encountering an error. The error message is not explicitly stated, but it seems to be related to the flashing process.
To resolve this issue, I would recommend following the steps outlined in the context for updating the Jetson Orin Nano Devkit from JetPack 5 to JetPack 6. Although the context is for updating to JetPack 6, the steps for preparing the SD card and booting the device may be applicable to your situation.
Here are the steps to try:
  1. Prepare an SD card with JetPack 5.1.1 SD card image. You can download it from JetPack SDK 5.1.1. Refer to Flashing the Image to an SD Card with Etcher to prepare the SD card image.
  2. Boot the Jetson Orin Nano Devkit with the JetPack 5.1.1 SD card inserted.
  3. When prompted to Press ESCAPE for boot options from the landing page of the UEFI menu, navigate to Boot Manager to check the boot order. Make sure the UEFI SD Device is on the top of the list. If it is not, refer to Customizing the Default Boot Order in the UEFI Menu for more information about changing the boot order in the UEFI menu.
  4. Complete the oem-config if needed.
If you are still encountering issues, you may want to try flashing the device manually using the flash.sh script. The context provides an example of how to flash the entire device using the flash.sh script.
Additionally, you may want to check the device-tree node configuration, as mentioned in the context, to ensure that it is correct for your device.
It’s also worth noting that the context mentions a few other topics related to flashing and booting Jetson devices, such as flashing to an NVMe drive, flashing to an SD card, and flashing for NFS as root. If you are experiencing issues with these topics, you may want to refer to the relevant sections in the context for more information.
In comparison to the provided context, it seems that the issue you are experiencing is related to flashing JetPack 5.1.2, whereas the context is focused on updating to JetPack 6. However, the steps for preparing the SD card and booting the device may still be applicable to your situation.
If you are still encountering issues after trying the above steps, please provide more details about the error message you are receiving, and I’ll do my best to assist you further.
This is related to PCN update. Trying jeptack5.1.5 shall be able to flash it.
