Jetson Orin Nano stopped booting
I am trying to setup my NVIDIA Jetson Orin Nano but and I had flashed the SD card with the image but when I turn on the board it brings “LT4Launcher attempting recovery boot” then goes off and fans stop spinning.
I have even changed SD cards but hasn’t changed. I have been on this issue for quite sometime how can I solve and be able to use my board.
Hello @rukundob32,
Have you already tried flashing with the sdk manager?
regards,
Andrew
Turn on the system
Go into UEFI Setup
Enter NVidia Configuration (don’t remember the exact wording)
Enter L4T Configuration
You should See an entry “OS Chain A” set to “unbootable”.
Change the “unbootable” to “ok”, save, exit, reboot, done
Hello @fchkjwlsq, thank you for the response.
Well, after following the steps under the nvidia configuration to change the L4T configuration to normal from unbootable then saving ok and rebooting as seen in the image below:
After the reboot or after starting the board once again the display showed is this as seen in the image below:
And then after display goes fans stop momentarily then get back on and no display. Monitor eventually goes to sleep.
How can I go about this and be able to finally use my NVIDIA Jetson Orin Nano Developer Kit?
