jetson Orin nano在显示了英伟达logo的界面显示
warning:test key is used
L4TLauncher:Attempting Direct Boot.
EFI stub:Booting Linux Kernel…
EFI stub:Using DTB from configuration table
EFI stub Loaded initrd from LINUX_EFI_INITRD)MEDIA_GUID device path
EFI stub:Exiting boot services and installing virtual address map…
然后就黑屏,风扇停转,过几秒钟然后风扇又开始转,但是没有画面输出
Try rebooting the unit again second time and see, if it’s boot normally.
If not take serial log during booting and analyse the log for root cause of the problem…
already rebooted several times ,still cant resolve this
Do this.
I remounted the Linux through sdkmanager and it works,thx u guys
