I just got a brand new orin nano 8GB. I flashed SD card based on instructions.
Plugged in monitor, keyboard, network, power…nothing.
Fan goes on for a while then shuts off.
How do I figure out what the problem is?
I just want to add that my host machine is Ubuntu 22.04, when I connect the USB C to my PC lsusb shows no NVIDIA devices, so the SDK manager doesn’t see it.
P.P.S I see talk about recovery mode, but no documentation on how to enable…so how to enable?
Thenb re-flash with SDK Manager.
Thanks. But I can’t even get it to boot the first time. I flashed a 256G SD card, and nothing happens when I
plug in keyboard
plug in mouse
plug in monitor
plug in power.
The fan comes on for about 1 minute then shuts off. So I can’t set it to recover mode via the command line. Is there another way (hardware button?)
YES, you need a jumper for it.
ok I’m listening… where do I find info for that?
Stuff like this:
https://www.amazon.com/ZYAMY-2-54mm-Standard-Circuit-Connection/dp/B077957RN7
Or even a dupont line can also do it.
Thanks. What pins do I have to jump?
FC REC and any of GND.
ok I will try that thanks
I’m also flashing a 128G SD now to see if that might have been a problem…
