I have tried to flash it with Ubuntu using the SDK. I have tried the flash from SD card method. It won’t recognize the unit using the SDK app. I have been unable to use jumpers to force reset. Please Help!
Please follow the Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation to put device into recovery mode.
Also refer to this section to check whether device in recovery mode.
I have tried to force reset the Jetson Orin Nano by shorting pins 9 and 10 using a jumper, copper wire, etc. none of those methods work.
- For the Jetson Orin Nano developer kit:
- Disconnect the power cable to ensure that the developer kit is powered off.
- Place a jumper to short the REC and GND pins on the 12-pin button header.
- Reconnect the power cable.
Do you disconnect the power cable before jump your device?
Got it! Thank you! I was using the 40 pin before. Everything is up and running! 🙏🏻
