We are trying to install ubuntu 20.04 OS over Jetson Nano Orin but It keeps failing to load user interface. We are working with ROS codes that’s why we need ubuntu version 20.04. We tried following method to run ubuntu on nano but failed.
- Using Nvidia SDK but the board is not being detected.
- Using flash method through SD card but this getting stuck in boot menu (some error called “startup.nsh”).
Please advise how to resolve this problem. Your help would be sincerely appreciated.
