Jetson Orin Nano Visual SLAM Tutorial Error
Hi, i’m following through this tutorial.
https://nvidia-isaac-ros.github.io/concepts/visual_slam/cuvslam/tutorial_realsense.html
cd /workspaces/isaac_ros-dev && \
  colcon build --symlink-install && \
  source install/setup.bash
when i run this command at step5,
this error occurs.
fatal error: isaac_ros_managed_nitros/managed_nitros_subscriber.hpp: No such file or directory
I’ve done all required tasks from the document.
I’ve also done git cloning isaac_ros_nitros source from github at /workspaces/isaac_ros-dev/src directory but the error keep occurs.
I am working on Jetson Orin nano, Ubuntu 20.04, ROS 2 Humble and docker.
I am new to Jetson and Nvidia, so sorry for my incapability.
Thank you.
I’ve deleted yolov8 directory and somehow it works
Hi @malslausiv, I’m happy to read that you have fixed your issue.
If you want to use Yolo8 as well, please add all dependencies following the quickstart documentation.
sudo apt-get install -y ros-humble-isaac-ros-yolov8 ros-humble-isaac-ros-tensor-rt ros-humble-isaac-ros-dnn-image-encoder
