[Visual SLAM on nvidia-isaac-ros using Docker] Error while launching Docker
Hello, I’m trying to implement Visual SLAM on my jetson orin nano, and following the steps in Setup instructions page [Isaac ROS RealSense Setup — isaac_ros_docs documentation]
I succesfully setup my Jetson Orin Nano board, and installed ROS2 from isaac-ros repository.
However, when I tried to launch Docker as shown in the step 4 on the setup instructions page [Isaac ROS RealSense Setup — isaac_ros_docs documentation], I got following errors:
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: could not apply required modification to OCI specification: error modifying OCI spec: failed to inject CDI devices: unresolvable CDI devices nvidia.com/gpu=all, nvidia.com/pva=all: unknown.
~/workspaces/isaac_ros-dev/src/isaac_ros_common
It seems that Docker-related configuration has not been set appropriately, but I have not yet found the reason. I created a /etc/cdi/nvidia.yaml file and set the contents as below (but the issue has not been solved):
cdiVersion: "0.4.0"
kind: "vendor"
devices:
  - name: "nvidia.com/gpu"
    containerSpec:
      mounts:
        - type: "bind"
          source: "/dev/nvidia0"
          destination: "/dev/nvidia0"
        - type: "bind"
          source: "/dev/nvidiactl"
          destination: "/dev/nvidiactl"
Could you give me some hints to solve the issue? Thank you!
Hi, I solved the issue by following the step below:
Jetson Setup for VPI
