Whatever the jetpack pre-installed in NVME SSD for Jetson Orin NX,
Is this driver customization being possible?
Moving this topic to the Jetson forums for visibility.
Most of NVME SSD devices are able to work.
Jetson devices can be booted from an NVMe drive. Hot-plugging is not supported; the NVMe drive must be attached before the Jetson device is booted.
We provide a way to simplify flashing to an NVMe drive that is connected to a Jetson device. For details, see To set up an NVMe drive as a boot device or root file system using flash with initrd.
