Hello, I saw on the nvidia forums that the jetson orin nano supports the Lepton 3.5, 160×120, 57° with shutter camera, but I have concerns about whether the Jetson orin nx card supports this Lepton 3.5, 160×120, 57° with shutter camera. Can anyone help me with this? If so, can you help me with how to install and use it? @KevinFFF
Suppose it’s USB camera. Suppose it can plug and play with it. If not you need to check with vendor to get the driver for ARM for it.
There is a connection for jetson orin nanos as in the picture above. I will make a similar connection for jetson orin nx and communicate via SPI. There is no USB-like plug-and-play feature. When I checked the forums of flir lepton and nvidia, I could not understand whether they support it directly or not. The jetson I will use will be Jetson Orin NX 16GB (ONX 16GB) - Ampere GPU + Arm Cortex-A78AE v8.2 64-bit CPU + 16 GB LPDDR5. I could not reach a conclusion in my flir lepton sdk reviews.
If I use the PureThermal 3 board with a plug-and-play USB output, can I get my work done without installing an SDK?
If you have more detailed information on this subject, please help me. Thanks for your feedback. @KevinFFF @ShaneCCC
For the driver needed or not you need to consult with vendor.
