I built usbmon.ko earlier today to take a look at it. While testing it I thought of your problem and following is a method for capturing a USB bus trace on Thor. Linux_for_Tegra/source/kernel/kernel-noble/Documentation/usb/usbmon.rst
usbmon is a software tap in the Linux USB host stack. It records URBs submitted to and completed by the host-controller driver. It is useful for determining how far enumeration progressed and whether a device reappeared on the USB2 or USB3 root hub.
It is not equivalent to a hardware USB protocol analyzer. It does not capture Type-C CC/PD signaling, LFPS, electrical/link-training behavior, or the individual USB packets on the wire.
For your case, it can show:
- The root-hub bus the device enumerated on. On my Thor Bus 2 is the SuperSpeed root hub and Bus 1 is the USB2 high-speed root hub. This makes an SS/SS+ → HS fallback immediately visible.
- The complete host-side control-transfer sequence during enumeration.
- Device, configuration, string, and BOS descriptor requests/responses, if enumeration progresses far enough to retrieve them.
- SuperSpeed/SuperSpeedPlus capability descriptors returned in the BOS descriptor.
- URB completion status, including stalls, timeouts, disconnects, and other errors reported by the host stack.
- The exact sequence of retries and enumeration attempts.
On my JetPack 7.2.1 kernel CONFIG_USB_MON is not set. For a diagnostic kernel, I started with the running kernel configuration and changed only CONFIG_USB_MON to a module.
Native build on Thor using GCC 13.2.0:
cd Linux_for_Tegra/source
# Sync the kernel source to the exact JetPack/L4T release being tested.
./source_sync.sh -k -t # jetson_39.2.1, jetson_39.2_GA, or jetson_38.4
export ARCH=arm64
# Adjust this path for your GCC 13 13.2.0 installation.
export TCBIN="/path/to/gcc-13/bin"
export PATH="$TCBIN:$PATH"
unset CROSS_COMPILE
export CC="$TCBIN/gcc-13"
export HOSTCC="$TCBIN/gcc-13"
export CXX="$TCBIN/g++-13"
export HOSTCXX="$TCBIN/g++-13"
KERNEL_SRC="$PWD/kernel/kernel-noble"
# Start with the configuration of the running JetPack kernel.
zcat /proc/config.gz > "$KERNEL_SRC/.config"
make -C "$KERNEL_SRC" ARCH=arm64 olddefconfig
# Enable CONFIG_USB_MON=m.
"$KERNEL_SRC/scripts/config" \
--file "$KERNEL_SRC/.config" \
--module USB_MON
grep CONFIG_USB_MON "$KERNEL_SRC/.config"
# Build the kernel and in-tree modules.
make -C kernel -j"$(nproc)"
Install the new usbmon module and test kernel Image:
sudo install -D -m 0644 \
"$KERNEL_SRC/drivers/usb/mon/usbmon.ko" \
"/lib/modules/$RUNREL/updates/drivers/usb/mon/usbmon.ko"
sudo install -m 0644 "$KERNEL_SRC/arch/arm64/boot/Image" /boot/Image-usbmon
sudo depmod -a
Add an extlinux.conf test entry
cat /boot/extlinux/extlinux.conf.
copy the existing primary boot entry
sudo nano /boot/extlinux/extlinux.conf
Paste copied text. Change the label/menu name and kernel Image, for example:
LABEL usbmon
MENU LABEL USBMON test kernel
LINUX /boot/Image-usbmon
INITRD /boot/initrd
APPEND <copy the complete APPEND line from the primary entry>
Reboot and select USBMON test kernel from the extlinux boot menu.
Once booted:
sudo modprobe usbmon
Then:
sudo ls /sys/kernel/debug/usb/usbmon
If needed identify the buses
usbmon2 records SuperSpeed.
usbmon1 records USB2.
usbmon0 records all usb devices.
Capture the problem. Start the kernel log and leave it running in another terminal:
sudo dmesg -wT | tee usbdmesg.txt
Start the USB capture:
sudo tcpdump \
-i usbmon0 \
-s 0 \
-U \
-w typec_fallback_diagnostic.pcap
While the captures are running, run your USB problem creation sequence.
After the failure has occurred stop tcpdump and the dmesg capture.
Analysis in Wireshark
wireshark typec_fallback_diagnostic.pcap &
A display filter that shows control transfers, including the enumeration sequence:
usb.transfer_type == 2
To show descriptor requests use:
usb.setup.bRequest == 6
usb.transfer_type == 2 || (usb.urb_type == 0x43 && usb.urb_status < 0)
For Nvidia @WayneWWW you could attach:
usbdmesg.txt
