I’m new to this forum, the world of Jetson TK1, and I REALLY need help resolving this issue. I’ve tried installing the Jetson TK1 Jetpack so many times I’ve literally lost count, and I always run into the same issue. Basically, I follow the steps outlined in the following link:
http://docs.nvidia.com/jetpack-tk1/index.html#developertools/mobile/jetpack_install.htm
once all of the software components are done downloading, i’m prompted to begin the install on the host computer. As soon as I select “Next” I get error messages (see messages below). Each and every time this happens, I go and review the folder, and edit the permissions (i.e. , sudo, root). I’ve tried changing the permissions on all directories and subdirectories using the “chmod -R 777 .run” file. I’ve tried running the *.run file in both root and non-root mode, and used the “sudo .run” command. Literally everything! And each time I re-run the *.run file, after changing the permissions, and assuming it would just utilize the previously downloaded files without having to spend hours again re-downloading them, the process aborts, and the files are locked again. Also, no *.log file is ever generated for me to send. Can someone PLEASE HELP ME!!! (also, I have images of previously mentioned issues but don’t know how to attach them in order to show the error messages).
ERROR MESSAGE #1:
“Installer aborted because of error. Please send ~/JetPackTK1-1.0/JetPackTK1-installLog.log to TegraDeveloperPack-Users@nvidia.com”
ERROR MESSAGE #2:
“There has been an error. Error running xterm -T “Need root privilege to install” -e “sudo ~/JetPackTK1-1.0/_installer/sudo_daemon-installer=29689 -d=~/JetPackTK1-1.0/_installer/tmp”:/bin/sh: 1: xterm: not found. The application will exit now.”
Thank you in advance!
grad_stud
