I just got a TX1 dev board and having problems installing the Jetpack. I have downloaded the jetpack but when i run the Jetpack from the terminal, all it does is creates an install directory and that’s it. No installation screen. I have given executable permission to Jetpack using chmod
What system are you doing the jetpack install on? Based on my understanding, the jetpack run script should be run on an Ubuntu 14.04 system that is not the Jetson TX 1
Serious answer, reinstall the host OS and redownload the Jetpack. I had the same issue and a reformat fixed it.
Please read my last reply to my topic JETPACK install fails…
I read your post. I had the same issue. A reformat fixed it. Sometimes Ubuntu installs improperly.
