We are working with a custom design based on Jetson TK1 board with another custom designed NXP’s single board computer. Both the custom boards had to communicate over PCIe through a PCIe switch(89HPES12NT3ZBBCGI) where Tegra Tk1 will be root complex and NXP’s processor will be endpoint. I am always failing to successfully establish a link between them.
I tried to communicate custom NXP’s board with NXP’s reference board and it detected both:PCIe switch and the endpoint processor. Then I replaced NXP’s reference board with Jetson TK1 but it again failed to establish a link.
In Uboot Jetson shows link up on port 0;that is connected to mini PCIe port; but when the board boots up, it does not show any device when I run lspci command. Please see the following logs on jetson TK1 kit
Uboot Logs
tegra-pcie: PCI regions:
tegra-pcie: I/O: 0x12000000-0x12010000
tegra-pcie: non-prefetchable memory: 0x13000000-0x20000000
tegra-pcie: prefetchable memory: 0x20000000-0x40000000
tegra-pcie: 2x1, 1x1 configuration
tegra-pcie: probing port 0, using 2 lanes
tegra-pcie: probing port 1, using 1 lanes
Lspci command
ubuntu@tegra-ubuntu:~$ lspci
00:00.0 PCI bridge: NVIDIA Corporation Device 0e13 (rev a1)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
Dmesg Command
ubuntu@tegra-ubuntu:~$ dmesg | grep pci
[ 0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 video=tegrafb mem=1862M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 vpr=151M@3945M tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal usb_port_owner_info=0 fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 tegra_fbmem=32899072@0xad012000 board_info=0x0177:0x0000:0x02:0x43:0x00 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt pci=noaer
[ 1.382249] pci_bus 0000:00: root bus resource [mem 0x32100000-0x3fffffff]
[ 1.382278] pci_bus 0000:00: root bus resource [mem 0x12100000-0x320fffff pref]
[ 1.382306] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 1.382331] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 1.382392] pci 0000:00:00.0: [10de:0e13] type 01 class 0x060400
[ 1.382488] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.382744] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.382942] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 1.382976] pci 0000:01:00.0: reg 10: [io 0x0000-0x00ff]
[ 1.383023] pci 0000:01:00.0: reg 18: [mem 0x00000000-0x00000fff 64bit]
[ 1.383055] pci 0000:01:00.0: reg 20: [mem 0x00000000-0x00003fff 64bit pref]
[ 1.383158] pci 0000:01:00.0: supports D1 D2
[ 1.383169] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.385316] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.385332] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 01
[ 1.385624] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 1.385652] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.385679] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
[ 1.385773] pcieport 0000:00:00.0: BAR 8: assigned [mem 0x32100000-0x321fffff]
[ 1.385803] pcieport 0000:00:00.0: BAR 9: assigned [mem 0x12100000-0x121fffff 64bit pref]
[ 1.385833] pcieport 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 1.385863] pci 0000:01:00.0: BAR 4: assigned [mem 0x12100000-0x12103fff 64bit pref]
[ 1.385908] pci 0000:01:00.0: BAR 2: assigned [mem 0x32100000-0x32100fff 64bit]
[ 1.385949] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.385977] pcieport 0000:00:00.0: PCI bridge to [bus 01]
[ 1.386000] pcieport 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 1.386025] pcieport 0000:00:00.0: bridge window [mem 0x32100000-0x321fffff]
[ 1.386054] pcieport 0000:00:00.0: bridge window [mem 0x12100000-0x121fffff 64bit pref]
[ 4.816718] ehci-pci: EHCI PCI platform driver
[ 13.980787] vgaarb: this pci device is not a vga device
[ 14.254782] vgaarb: this pci device is not a vga device
[ 19.815777] vgaarb: this pci device is not a vga device
[ 19.825720] vgaarb: this pci device is not a vga device
[ 620.495872] vgaarb: this pci device is not a vga device
Can someone comment what might be the possible reason of this issue?
