I am using J120 board + Jetson tx1 and I am having problem with getting video on the monitor.
Board seems to be working (green LED in on and ethernet LED is working) and also Jetson seems to be working (it is warm and I can turn it on/off via buttons on board).
Problem is that when I connect it to monitor I am getting black screen. When I disconnect Jetson from monitor I am getting “Check cable” on monitor, but when I connect Jetson I am getting “No signal”.
Currently I am using HDMI cable + little HDMI mini converter. Cable and converter are 100% working because I tested them on different devices with same monitor.
Logging into your TX1 would help to find out the issue.
You can do this with ssh if your TX1 has network configured and connected, otherwise you will have to use serial console if available on J120 board.
Once logged in, you should be able to see kernel traces with
dmesg
Using
dmesg --follow
you will see traces as they happen.
Then unplugging / replugging your HDMI cable will generate traces that you can try to analyze.
Thank you for help, but problem was in Jetson TX1. Because we bought it without development kit it was empty so we need to flash him with everything needed.
