你好:
在OEM的手册中,第11章 Figure 37 看到Recovery 的模式选择管脚分别为button-volup和BUTTON-VOL-DOWN,分别对应FORCE-RECOV#和CHARGING#两个信号。而在Demo板的原理图中,BUTTON-VOL-DOWN按钮对应的是SLEEP信号,请问,到底应该以哪个为准。
Hi BillBai,
Welcome to Jetson & Embedded Systems developer forum.
Please create the topic and issue in English manner.
Other developers can understand your issue and to share their experience with you quickly if they ever met similar issue in design stage.
And then other users could be leverage from this issue to get benefits.
Thank you.
Yep
When I saw the OEM datasheet ,chapter 11 Figure 37,there is a Recovery mode which selected by two Pins.
So the datasheet said the two pins are FORCE_RECOV#(BUTTON-VOLUP) and CHARGING#(BUTTON-VOLDOWN).
But in the Demo schematics, Button-VOLDOWN signal is SLEEP#.
SO problem is coming, which signals are Recovery mode select pins?just CHARGING# or SLEEP#?
Hi BillBai,
No conflict here, BUTTON_VOL_DOWN is a ball name of TX1 chip, key S2 (VOL DOWN) on carrier board is a button connected to SLEEP not to BUTTON_VOL_DOWN.
Yes,Thank you for answer my question!
