My Jetson TX1 is permanently stuck in the Force Recovery mode. I tried to flash the device but this didn’t make any change to the state of the TX1.
Things I tried:
Flash with different VMs and Host Machines, both running 14.04 Ubuntu
Flash custom images and vanilla firmware from Nvidia
Tried with changing the Micro-USB-Cable
Tried different carrier boards 2x Auvidea J120 and one DEV-Kit
Ping on IPv4 and on IPv6 to determine if network is up, failed
Tried different Monitors to see if the linux kernel boots up, nothing to see
Tried with different Network Setup
Successfully tested the environment with flashing another TX1, wich worked perfectly fine.
What I noticed is, that whenever I restart or unplug the cable the Jetson will be listed as an USB-Device, like it should be when you are putting it into the Force Recovery Mode. Just when I finished flashing the Device and JetPack is trying to determine the IP-Address then the Device ist not listed as an USB-Device checked with: “lsusb”
Does anybody have an idea how to fix this state?
