I power on my Jetson TX1, it displays the boot screen but then it does not display properly the desktop unity. It does not display the menu items/icons, it just flicker some files I have saved on Desktop and that´s all…
I am not even able to open with Ctrl + Alt + F1
Last time I worked on the TX1, everything seemed to work properly, I installed Tensorflow on a mounted SSD, where I had to create a swap file to be able to run some examples for transfer learning, but everything was ok then I powered off TX1 from command line and now I try to open it and BAM!
I am wondering if there was some update that was not done appropriately that makes it crash or if it is related with the swapfile i created.
Can you please help me to figure out what is going on? I really want to avoid to flash it again…
Sound would fail unless sound has been configured. I doubt the mixer failure has anything to do with video failure.
I think nvidia-xconfig has never shipped with the L4T on a TX1. Whether having it would even work I don’t know, but I suspect the application depends on a PCI video driver, and the TX1 video is not via PCI.
Running X and logging in does require creating some temp files and lock files. Running out of space would break that. There is a strong chance that the lack of disk space is the cause (this would break session handling if locks go to the storage which has nothing left on it).
Shall I remove files from /tmp and /var/log folders?
For example, removing syslog.*.gz? or change how often they are created?
I am afraid not to move something critical for the system…
If i move everything of /tmp and /var/log to my mounted SSD?
Is there may be a command to define a folder in my external SSD for the temp files of the boot process?? Changing may be env variable TMPDIR? If so, how should I do it?
If you have other suggestions to free space, that would be very useful
Logs typically are rotated once daily. They can be an issue if they get large from some constant error message. In an emergency you could delete older logs with the numeric extension on their file name, e.g., kern.log is a running log, kern.log.1 is an old log…I’d just delete old logs first. If something is wrong existing logs might be useful to see what’s going on.
About disk space…what is causing it to fill up? What is the output of “df -H -T /”?
Realize that if lock file space is all that is needed it won’t take much in the way of file deletes to be able to log in (though you might still reboot first…and if something is constantly filling logs or disk space in other places, then it just might do it again before you get logged in).
Temp files for use at startup are part of init. I don’t know where to change that configuration, but I don’t think it would be as simple as changing a variable. For your individual user each application might use its own temp dir. Lock files are definitely in their own directory. More information on why space is filled up would be of use, along with any differences in a flash which may have been non-standard.
NOTE: gzip and bzip2 require some temp space to compress, but if you’ve freed up a bit of free space “bzip2 -9” of files which are large (but which you want to keep) is a good temporary measure.
I tried to execute apt-get clean and I get the following error
sudo apt-get clean
[sudo] password for ubuntu:
E: Could not get lock /var/cache/apt/archives/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/cache/apt/archives/
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
I move them to lock_bak files to “free” them, and I get this error again, new lock files have been created and i get this error…
Not sure if this is related
My purpose is to be able to free space but seems that no matter what i do, space remains the same and I do not understand why moving files makes no effect… may be there are not moved actually… could they be sym links? If so, where are the real ones stored?
May be freeing space on eMMC Flash works differently. Any suggestions?
Also what I saw, if that is of any help, current file for syslog is empty… and syslog.1 was written 3 days before… Same for kern.log… This is the last date I was able to see graphics in a proper way, I guess lack of space affects IO processes.
With du -sh * . I saw that /home was using more of the space. Running the command recursively inside Home, i found that the folder .cache/bazel was 3.3G , I moved this folder to my mounted SSD and GUI is loading properly now.
So , now the remaining thing would be to configure Bazel to cache files in a non-default folder directory, inside the mounted SSD.
Thanks for your overall help on this post, I appreciate :)
