I have received the Jetson TK1 board today.
As I powered it up, I did not see a GUI loading. I logged in (text based) using the username and password, and peformed the following:
sudo apt-get update
sudo apt-get upgrade
sudo shutdown -r now
The unity desktop still did not load.
I tried booting it manually by
sudo unity
and got the message
No display variable set
and later by
sudo service lightdm start
but no success there…
Any suggestions
Nico
June 10, 2014, 7:17am
#2
I didn’t see a GUI either when I received mine.
After installing L4T R19.2 everything worked as expected.
https://developer.nvidia.com/sites/default/files/akamai/mobile/files/L4T/l4t_quick_start_guide.txt
OK, I flashed the device
It seems to boot, however the boot gets stuck with a message:
Can’t set audio to 44100 at 13850400 pix_clock
It has something to do with the HDMI and I’m not sure why I’m even getting this.
cosminb
December 16, 2014, 3:51pm
#4
Did you eventually fix the issue?
I am too having problems with my HDMI connection.
I’ll try to flash 21.2 to it, and see if it will work.
Cynar
December 16, 2014, 10:41pm
#5
There is currently an issue with apt-get update overwriting a critical file.
run
sudo apt-mark hold xserver-xorg-core
beforehand to protect it.
Larch
December 17, 2014, 12:51am
#6
Did you installed the gpu drivers inside the /home/ubuntu/NVIDIA-INSTALLER folder?
cosminb
December 17, 2014, 2:02pm
#7
In my case, flashing the 21.2 version fixed the issue. No need for anything else.
