Hello, I have a problem with flashing Jetson TX2 Development Kit on Ubuntu 18.04 LTS via WSL2. During the flash operation the USB connection is detached and attached back but as a result the flash.sh script fails after several disconnection/connection cycles. Could you propose a solution of my problem?
19:43:18 INFO: CUDA Toolkit for L4T - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb
19:43:19 INFO: cuDNN on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libcudnn8_8.2.1.32-1+cuda10.2_arm64.deb
19:43:19 INFO: cuDNN on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libcudnn8-dev_8.2.1.32-1+cuda10.2_arm64.deb
19:43:19 INFO: cuDNN on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libcudnn8-samples_8.2.1.32-1+cuda10.2_arm64.deb
19:43:19 INFO: TensorRT on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libnvinfer8_8.2.1-1+cuda10.2_arm64.deb
19:43:19 INFO: TensorRT on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libnvinfer-dev_8.2.1-1+cuda10.2_arm64.deb
19:43:19 INFO: TensorRT on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin8_8.2.1-1+cuda10.2_arm64.deb
19:43:19 INFO: TensorRT on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin-dev_8.2.1-1+cuda10.2_arm64.deb
19:43:19 INFO: TensorRT on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libnvonnxparsers8_8.2.1-1+cuda10.2_arm64.deb
19:43:19 INFO: TensorRT on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libnvonnxparsers-dev_8.2.1-1+cuda10.2_arm64.deb
19:43:19 INFO: OpenCV on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb
19:43:19 INFO: OpenCV on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb
19:43:19 INFO: OpenCV on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-licenses.deb
19:43:19 INFO: OpenCV on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-python.deb
19:43:19 INFO: OpenCV on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-samples.deb
19:43:19 INFO: OpenCV on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-licenses.deb with correct checksum, skip downloading.
19:43:19 INFO: OpenCV on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb with correct checksum, skip downloading.
19:43:19 INFO: TensorRT on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/libnvonnxparsers-dev_8.2.1-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
19:43:19 INFO: TensorRT on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/libnvonnxparsers8_8.2.1-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
19:43:19 INFO: TensorRT on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin-dev_8.2.1-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
19:43:19 INFO: cuDNN on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/libcudnn8-samples_8.2.1.32-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
19:43:19 INFO: OpenCV on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-samples.deb with correct checksum, skip downloading.
19:43:19 INFO: TensorRT on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/libnvinfer-plugin8_8.2.1-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
19:43:19 INFO: OpenCV on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-python.deb with correct checksum, skip downloading.
19:43:19 INFO: TensorRT on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libnvparsers8_8.2.1-1+cuda10.2_arm64.deb
19:43:19 INFO: TensorRT on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libnvparsers-dev_8.2.1-1+cuda10.2_arm64.deb
19:43:19 INFO: TensorRT on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libnvinfer-bin_8.2.1-1+cuda10.2_arm64.deb
19:43:19 INFO: TensorRT on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libnvinfer-doc_8.2.1-1+cuda10.2_all.deb
19:43:19 INFO: TensorRT on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/libnvinfer-bin_8.2.1-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
19:43:19 INFO: TensorRT on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/libnvparsers-dev_8.2.1-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
19:43:19 INFO: TensorRT on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/libnvparsers8_8.2.1-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
19:43:28 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
19:43:29 INFO: TensorRT on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_8.2.1-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
19:43:29 INFO: TensorRT on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_8.2.1-1+cuda10.2_arm64.deb
19:43:29 INFO: TensorRT on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/uff-converter-tf_8.2.1-1+cuda10.2_arm64.deb
19:43:29 INFO: TensorRT on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_8.2.1-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
19:43:29 INFO: TensorRT on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/uff-converter-tf_8.2.1-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
19:43:29 INFO: VisionWorks on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libvisionworks-repo_1.6.0.501_arm64.deb
19:43:29 INFO: VisionWorks on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4.501_arm64.deb
19:43:29 INFO: VisionWorks on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4.501_arm64.deb with correct checksum, skip downloading.
19:43:29 INFO: VisionWorks on Target - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2.501_arm64.deb
19:43:29 INFO: VisionWorks on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2.501_arm64.deb with correct checksum, skip downloading.
19:43:29 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-cuda_10.2.460-1_arm64.deb
19:43:29 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-cuda_10.2.460-1_arm64.deb with correct checksum, skip downloading.
19:43:29 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-cudnn_8.2.1.32-1+cuda10.2_arm64.deb
19:43:29 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-cudnn_8.2.1.32-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
19:43:29 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-tensorrt_8.2_arm64.deb
19:43:29 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-tensorrt_8.2_arm64.deb with correct checksum, skip downloading.
19:43:29 INFO: VisionWorks on Target - target: Found file /home/andrey/Downloads/nvidia/sdkm_downloads/libvisionworks-repo_1.6.0.501_arm64.deb with correct checksum, skip downloading.
19:43:29 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-visionworks_1.6.0.501_arm64.deb
19:43:29 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/andrey/Downloads/nvidia/sdkm_downloads/libnvidia-container0_0.10.0+jetpack_arm64.deb
19:43:47 INFO: Start to check If Jetson device Ready To Flash Recovery...
19:43:47 INFO: Start to check bootrom status...
19:43:47 DEBUG: running command < true >
19:43:47 INFO: exec_command: true
19:43:47 INFO: [host] [sudo] password for andrey:
19:43:47 INFO: net.ipv4.ip_forward = 1
19:43:47 INFO: Device mode on host successfully set with DNS 8.8.8.8!
19:43:47 INFO: command finished successfully
19:43:47 INFO: Device info before flash: Jetson TX2 | 001/002 | 1-1 | 2.00 | Recovery | 0955:7c18
19:43:48 DEBUG: running command < true >
19:43:48 INFO: exec_command: true
19:43:51 INFO: Flash Jetson TX2 - flash: [ 3.2744 ] List of rcm files are saved in rcm_list.xml
19:43:51 INFO: Flash Jetson TX2 - flash: [ 3.2744 ] Signing RCM messages
19:43:51 INFO: Flash Jetson TX2 - flash: [ 3.2774 ] tegrasign_v3.py --key None --list rcm_list.xml --pubkeyhash pub_key.key
19:43:51 INFO: Flash Jetson TX2 - flash: [ 3.2775 ] Assuming zero filled SBK key
19:43:51 INFO: Flash Jetson TX2 - flash: [ 3.2856 ] Copying signature to RCM mesages
19:43:51 INFO: Flash Jetson TX2 - flash: [ 3.2880 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
19:43:56 INFO: Flash Jetson TX2 - flash: [ 3.2899 ]
19:43:59 INFO: Flash Jetson TX2 - flash: [ 9.6369 ]
19:43:59 INFO: Flash Jetson TX2 - flash: --- Reading board information succeeded.
19:43:59 INFO: Flash Jetson TX2 - flash: Parsing baseboard EEPROM:
19:43:59 INFO: Flash Jetson TX2 - flash: --- Parsing board ID (2597) succeeded.
19:43:59 INFO: Flash Jetson TX2 - flash: --- Parsing board version (501) succeeded.
19:44:00 INFO: Flash Jetson TX2 - flash: --- Parsing board SKU (0000) succeeded.
19:44:00 INFO: Flash Jetson TX2 - flash: --- Parsing board REV (C.0) succeeded.
19:44:00 INFO: Flash Jetson TX2 - flash: Parsing module EEPROM:
19:44:00 INFO: Flash Jetson TX2 - flash: --- Parsing board ID (3310) succeeded.
19:44:00 INFO: Flash Jetson TX2 - flash: --- Parsing board version (B02) succeeded.
19:44:00 INFO: Flash Jetson TX2 - flash: --- Parsing board SKU (1000) succeeded.
19:44:00 INFO: Flash Jetson TX2 - flash: --- Parsing board REV (B.0) succeeded.
19:44:00 INFO: Flash Jetson TX2 - flash: jetson-tx2-devkit found.
19:44:00 INFO: Flash Jetson TX2 - flash: *** Finding boot device ... Boot device mmcblk0p1 found.
19:44:00 INFO: Flash Jetson TX2 - flash: "/home/andrey/nvidia/nvidia_sdk/JetPack_4.6.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/flash.sh" -C nv-auto-config jetson-tx2-devkit mmcblk0p1
19:44:00 INFO: Flash Jetson TX2 - flash: ###############################################################################
19:44:00 INFO: Flash Jetson TX2 - flash: # L4T BSP Information:
19:44:00 INFO: Flash Jetson TX2 - flash: # R32 , REVISION: 7.6
19:44:00 ERROR: Flash Jetson TX2 - flash: Error: probing the target board failed.
19:44:00 ERROR: Flash Jetson TX2 - flash: Make sure the target board is connected through
19:44:00 ERROR: Flash Jetson TX2 - flash: USB port and is in recovery mode.
19:44:00 ERROR: Flash Jetson TX2 - flash: *** ERROR: flashing failed.
19:44:00 ERROR: Flash Jetson TX2 - flash: [exec_command]: /bin/bash -c /home/andrey/.nvsdkm/replays/scripts/JetPack_4.6.6_Linux/NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh; [error]: *** ERROR: flashing failed.
19:44:00 INFO: Flash Jetson TX2 - flash: [ Component Install Finished with Error ]
19:44:00 INFO: Flash Jetson TX2 - flash: [host] [ 2.56 MB used. Disk Avail on Partition /dev/sdc: 926.99 GB ]
19:44:00 INFO: Flash Jetson TX2 - flash: [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 12s ]
19:44:00 ERROR: command error code: 11
19:44:00 ERROR: Flash Jetson TX2 - flash: command terminated with error
19:44:00 SUMMARY: Flash Jetson TX2 - flash: First Error: Jetson board is in a bad state and cannot be recovered. Please manually put board to recovery mode again and retry.. The Jetson target is in a bad state and cannot be flashed. Please manually put the target into recovery mode and then retry flashing.
19:44:00 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
19:44:00 SUMMARY: Multimedia API - target: Depends on failed component
19:44:00 SUMMARY: TensorRT on Target - target: Depends on failed component
19:44:00 SUMMARY: VisionWorks on Target - target: Depends on failed component
19:44:00 SUMMARY: VPI on Target - target: Depends on failed component
19:44:00 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
19:44:00 SUMMARY: cuDNN on Target - target: Depends on failed component
19:44:00 SUMMARY: OpenCV on Target - target: Depends on failed component
19:44:00 SUMMARY: Nsight Systems - target: Depends on failed component
19:44:00 SUMMARY: DateTime Target Setup - target: Depends on failed component
