I need to decode H265 stream to image in YUV format, so I use /tegra_multimedia_api/samples/00_video_decode to do this.
This sample can decode H265 file to YUV video file successfully, But I need to use camera to capture H265 stream and perform real-time decoding. When I decode H265 I frame, I can got YUV image, when inputting H265 P frame, the output image is abnormal.
How to solve this problem?
My h265 stream is captured by a camera, when I capture one frame, I call the read_decoder_input_chunk( ctx->in_file[current_file], buffer) function to read one frame h265 stream, and then decode to the YUV data. So I dont’t store the h265 stream to a file.
The /tegra_multimedia_api/samples/00_video_decode sample can read all frame from input file to buffer, and decode successfully. But how can I read one frame to decode, and then read next frame to decode?
// Read encoded data and enqueue all the output plane buffers.
// Exit loop in case file read is complete.
i = 0;
while (!eos && !ctx.got_error && !ctx.dec->isInError() &&
i < ctx.dec->output_plane.getNumBuffers())
struct v4l2_buffer v4l2_buf;
struct v4l2_plane planes[MAX_PLANES];
NvBuffer *buffer;
memset(&v4l2_buf, 0, sizeof(v4l2_buf));
memset(planes, 0, sizeof(planes));
buffer = ctx.dec->output_plane.getNthBuffer(i);
if ((ctx.decoder_pixfmt == V4L2_PIX_FMT_H264) ||
(ctx.decoder_pixfmt == V4L2_PIX_FMT_H265))
if (ctx.input_nalu)
read_decoder_input_nalu(ctx.in_file[current_file], buffer, nalu_parse_buffer,
CHUNK_SIZE, &ctx);
else
read_decoder_input_chunk(ctx.in_file[current_file], buffer);
if (ctx.decoder_pixfmt == V4L2_PIX_FMT_VP9)
ret = read_vp9_decoder_input_chunk(&ctx, buffer);
if (ret != 0)
cerr << "Couldn't read VP9 chunk" << endl;
v4l2_buf.index = i;
v4l2_buf.m.planes = planes;
v4l2_buf.m.planes[0].bytesused = buffer->planes[0].bytesused;
if (ctx.input_nalu && ctx.copy_timestamp && ctx.flag_copyts)
v4l2_buf.flags |= V4L2_BUF_FLAG_TIMESTAMP_COPY;
ctx.timestamp += ctx.timestampincr;
v4l2_buf.timestamp.tv_sec = ctx.timestamp / (MICROSECOND_UNIT);
v4l2_buf.timestamp.tv_usec = ctx.timestamp % (MICROSECOND_UNIT);
if (v4l2_buf.m.planes[0].bytesused == 0)
if (ctx.bQueue)
current_file++;
if(current_file != ctx.file_count)
continue;
if(ctx.bLoop)
current_file = current_file % ctx.file_count;
continue;
// It is necessary to queue an empty buffer to signal EOS to the decoder
// i.e. set v4l2_buf.m.planes[0].bytesused = 0 and queue the buffer
ret = ctx.dec->output_plane.qBuffer(v4l2_buf, NULL);
if (ret < 0)
cerr << "Error Qing buffer at output plane" << endl;
abort(&ctx);
break;
printf("v4l2_buf.m.planes[0].bytesused =%d\n",v4l2_buf.m.planes[0].bytesused);
eos = true;
cout << "Input file read complete" << endl;
break;
i++;
Or can you provide H265 video stream real-time processing sample programs and documents? I need input one frame to decode to YUV image, and then input next frame to decode to YUV image.
i.e. 1.H265 I frame data → video decoder → YUV data
2.H265 P frame data → video decoder → YUV data
3.H265 P frame data → video decoder → YUV data
7.H265 I frame data → video decoder → YUV data
8.H265 P frame data → video decoder → YUV data
9.H265 P frame data → video decoder → YUV data
Yes, I store h265 stream to a file one by one frame. but 00_video_decode can’t decode the H265 P frame by only one frame.
I think the decoder don’t store the frame header info.
We need to deal the video in real-time, and if we record in all I frames, the H265 encode will lose its significance.
In my application scenario, can you provide a feasible solution?
Hi xyj,
We have delivered samples demonstrating all HW functions. Please realize you have to integrate into your own case. If you see issue in h265 decoding, you can store a h265 stream and attach it. Once we got the h265 stream, we will run 00_video_decode to reproduce the issue.
