We are trying to capture raw video from camera. First plan is using an hd-sdi to PCI express converter. If it fails we will looking for contervers to ethernet or to usb. Actually sci is also works.
The problem is I couldn’t find any data of which converter is compatible with tx2. We need a dual channel 1080p 30 fps hd-sdi to pcie converter. Do you have any recommendation?
