Jetson TX2 NX current consumption behaviour
We are currently using the NVIDIA TX2 NX with a custom-designed carrier board. We have observed that the module draws current in a seemingly random manner, where the current occasionally spikes to a peak and then drops back down, resulting in noticeable fluctuations between higher and lower current levels.
Our end customer has requested that we confirm whether this is a known behavior of the NVIDIA TX2 NX. Specifically, instead of maintaining a steady-state current when the device is in standby, we are observing intermittent current spikes.
Could you please confirm if this behavior is expected?
@JerryChang
~0324
Do you see the same behavior on the NVIDIA Dev Kit carrier board with the default JetPack image installed?
