I would like to know which power supply is suitable for a Jetson TX2 NX to work at full capacity.
I am using a 5V 4A power supply and while I try to run yolov5 the process dies automatically. I am using my “tx2 nx module” on the carrier board of a jetson nano B01.
Thank you.
As you’re using Nano carrier board, yu’ll definitely need to use the barrel jack power supply connector on the Jetson Nano Developer Kit carrier board.
Use a quality power supply like the ones we list in Jetson Nano SCL , but take note that the Jetson Nano Developer Kit User Guide specifies a maximum supported continuous current of 4.4A for the Nano reference carrier board.
