I want to design power monitoring with reference to P2597_B04_OrCAD schematic. Why are resistors R163, R151 and R141 (680K) used? Do I need to use it?
Secondly, why are the capacitances C99, C89, and C78 used as 4.7uF? In the INA3221 datasheet, this value is suggested as 0.1uF - 1uF. Do you mind if I use 1uF?
Third, why are the IN+ and IN- pins drawn at 90 ohms? Is it possible to draw at other impedance values?
