Please help to install jetpack version above 4 .5 in tx2 development board. For that which version of SDK manager should use??. I tried to install jetpack version above 4.0 but the development board supportive peripherals like usb,rj45 won’t working. I like to install jetpack above 4.0 with higher version of tensorflow gpu(>2.0v).
Hello and welcome to the forums! This topic belongs in the Jetson category, I will move it over for you.
JetPack/SDK Manager is a helper frontend to the actual flash software (the actual flash software is the “driver package” since it understands a recovery mode Jetson on USB). What gets flashed is “Linux for Tegra” (L4T), which in turn is Ubuntu plus NVIDIA drivers. The L4T release and JetPack/SDKM releases are tied together, so if you pick one, then you know the other as well.
Basically, you should pick the most recent compatible L4T release, and use that. Documentation for each release is found with the release URL. See:
Note that you have to have at least Xavier to work with any JetPack 5.x+. The TX2 is old enough that it is restricted to the JetPack 4.x.
so jetpack above 4 won’t work in jetson tx2 developer kit?
For TX2, please use Jetpack 4.6.3.
Jetpack 5 supports Xavier and Orin series.
Which SDK manager version to use for install jetpack 4.6.3
When I install jetpack 4.3.6 ver the peripherals like HDMI port, rj45,usb port won’t working. Only jetpack 3.3 working. Please help for install jetpack ver 4+ for working with tensorflow gpu ver 2+.
See 4.6.3 at:
https://developer.nvidia.com/jetpack-sdk-463
