Body/enclosure of TX2i is connected to Ground. I want to design a system with isolated ground. is it possible to remove the ground connection from body/enclosure. even the top mounting screw is PAN head type is it possible to get CSK variant.
Hi, what does the ‘body/enclosure’ mean? Do you mean the ground of your system is not connected to TTP/BOX?
yes, Ground of my system is not connected directly to TTP/BOX. i need isolation between
input ground, enclosure ground and digital ground.
