I executed command: “sudo apt-get —reinstall install python3-numpy python-numpy” and reinstalled jetson-inference, but it didnt help.So i have a question:
Could you explain me please how does the system works if i have 2 (or more) versions of python installed (I have python 3.6 and python 3.7 as default in my system) ?Does it install specific version of numpy for each of them or for only one ?If so, how can i install numpy for python 3.6 and how can i set python 3.6 as default ?
Hi. python3 --version show 3.7.1.And python 3.7 was default in my system from the start; i didnt do anything to make it default.I executed command: sudo update-alternatives --install /usr/bin/python3 python3 /usr/bin/python3.6 1, but ,it seems, it didnt do anything.I couldnt set python 3.6 as default.
What OS and version of Ubuntu are you using? Because on JetPack 4 and Ubuntu 18.04, Python 3.6 is the default version of Python3 out of the box.
I also see in your screenshot you appear to have anaconda running, which may be related to some of your issues regarding the default Python versions. I also haven’t tested jetson-inference in conda/miniforge, and jetson-inference/jetson-utils will install it’s Python bindings under /usr/local/lib/python3.x (not anaconda location)
If you continue having issues, I recommend that you try the jetson-inference docker container, as it already has everything pre-installed for you with the correct Python environment and configuration.
Thanks for your reply.I installed the docker container, but i couldnt execute my programm on it, so could you explain me, please, how to import my files in the container to execute my programm ?
I tried this command “docker/run.sh --volume /my/host/path:/my/container/path”, but it didnt work.
The container didn’t start, because there was an erroneous $ symbol in your command. Try it again without that.
Then once you are in the container, the prompt should change to showing root user and a # symbol. Then cd /home/atlas/jetson-inference (this is the location you mounted your volume into the container at). Then run ls and see if you see 2.py. Then you can try to run 2.py with python3 2.py
