Which Jetson platform you’re using?
Which JetPack SW?
I don’t see any issues with the screenshot you posted.
Can you please elaborate more?
I’m using Jetson Nano Developer Kit with DC barrel jack for 4G kit. Every time i wanted to log into the Jetson, it keeps on saying connection reset. To log in I basically have to ping first then use the ssh command but it does not log in immediately.
Once i logged in, it keeps on resetting the connection before i have the chance to input the command. Thank you.
You should check this:
