I have cloned Xavier AGX into sd card by following the and i already successfully got system.img
Everything is done well, until when i try to flash it i getting error.
When the my device is in recovery mode, i use lsusb command on HOST and there is list line of Nvidia Corp show but i still getting the error
Did i do anything wrong while trying to flash.sh?
command : sudo ./flash.sh -r - system.img mmcblk1p1
Error : probing the target board failed. Make sure the target board is connected through USB port and is in recovery mode
nvidia corp in lsusb is no longer a 100% precise way to make sure your board is in RCM after rel-32.
Even in normal status, our usb port will serve as device mode so you can see nvidia corp from host too…
Please connect micro usb port on your xavier devkit to your host and open /dev/ttyUSB3 on your host. This will show the uart console, if your board is in recovery mode, then the uart console should suddenly give no response to your command.
