hi,
I’m new to Nvidia Jetson xavier platform and want to use typeC interface to output connecting 4k screen, but the screen does not work?
i capture the dmesg info and find the print information below,
[ 3321.713751] ucsi_ccg 1-0008: port0 evt: Type-C Port Connect Detected
[ 3321.715823] ucsi_ccg 1-0008: [typec-port0] Cable state:1, cable id:2
[ 3322.841860] ucsi_ccg 1-0008: port0 evt: PD Contract Negotiation Complete
[ 3322.844826] ucsi_ccg 1-0008: get_current_pdo: 2601905a:
[ 3322.844844] ucsi_ccg 1-0008: [typec-port0] DO type 0, max_current 90, voltage 100
[ 3323.479765] ucsi_ccg 1-0008: port0 evt: VDM Received
[ 3323.479805] ucsi_ccg 1-0008: vdm_hdr: svid: ff00, cmd: Discover Identity (1) cmd_type: ACK, obj_pos: 0
[ 3323.483692] ucsi_ccg 1-0008: port0 evt: VDM Received
[ 3323.483710] ucsi_ccg 1-0008: vdm_hdr: svid: ff00, cmd: Discover SVIDs (2) cmd_type: ACK, obj_pos: 0
[ 3323.487335] ucsi_ccg 1-0008: port0 evt: Alternate Mode event
[ 3323.490988] ucsi_ccg 1-0008: port0 evt: VDM Received
[ 3323.491005] ucsi_ccg 1-0008: vdm_hdr: svid: ff01, cmd: Discover Modes (3) cmd_type: ACK, obj_pos: 0
[ 3323.498347] ucsi_ccg 1-0008: port0 evt: Alternate Mode event
[ 3323.499489] ucsi_ccg 1-0008: pin assign: C E
[ 3323.506776] ucsi_ccg 1-0008: port0 evt: Alternate Mode event
[ 3323.510335] ucsi_ccg 1-0008: == ALTMODE discover complete
[ 3323.518883] ucsi_ccg 1-0008: port0 evt: VDM Received
[ 3323.520014] ucsi_ccg 1-0008: vdm_hdr: svid: ff01, cmd: Enter Mode (4) cmd_type: ACK, obj_pos: 1
[ 3323.527254] ucsi_ccg 1-0008: port0 evt: Alternate Mode event
[ 3323.527266] ucsi_ccg 1-0008: == ALTMODE entered: id = 0, svid = ff01
[ 3323.530958] ucsi_ccg 1-0008: port0 evt: VDM Received
[ 3323.531017] ucsi_ccg 1-0008: vdm_hdr: svid: ff01, cmd: DP Status Update (16) cmd_type: ACK, obj_pos: 1
[ 3323.531054] ucsi_ccg 1-0008: connected: 2, power_low: 0, enabled: 1, multi-func: 0
usb_req: 0, exit_dp: 0, hpd_state: 0, irq_hpd: 0
[ 3323.534460] ucsi_ccg 1-0008: port0 evt: VDM Received
[ 3323.534474] ucsi_ccg 1-0008: vdm_hdr: svid: ff01, cmd: DP Configure (17) cmd_type: ACK, obj_pos: 1
[ 3323.534486] ucsi_ccg 1-0008: update_typec_extcon_dp_mode: set prop dp_lane_num=4
[ 3323.537568] ucsi_ccg 1-0008: port0 evt: Alternate Mode Hardware event
[ 3323.564120] tegradc 15210000.nvdisplay: dp: plug event received
[ 3323.564195] hpd: state 3 (Disabled), hpd 1, pending_hpd_evt 1
[ 3323.564203] hpd: switching from state 3 (Disabled) to state 0 (Reset)
[ 3323.564951] ucsi_ccg 1-0008: port0 evt: VDM Received
[ 3323.564973] ucsi_ccg 1-0008: vdm_hdr: svid: ff01, cmd: Attention (6) cmd_type: Initiator, obj_pos: 1
[ 3323.567980] ucsi_ccg 1-0008: port0 evt: Alternate Mode Hardware event
[ 3323.665941] hpd: state 0 (Reset), hpd 1, pending_hpd_evt 0
[ 3323.665965] tegradc 15210000.nvdisplay: blank - powerdown
[ 3323.666013] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 3323.666018] Extcon DP: HPD disabled
[ 3323.666023] hpd: hpd_switch 0
[ 3323.666028] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 3323.666086] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[ 3323.666095] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[ 3323.673922] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 3323.678509] tegra_edid_get_monspecs: no modes in EDID base block
[ 3323.686993] tegra_edid_get_monspecs: EDID has no valid modes
[ 3323.687147] hpd: switching from state 2 (Check EDID) to state 2 (Check EDID)
[ 3323.693891] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 3323.698437] tegra_edid_get_monspecs: no modes in EDID base block
[ 3323.706659] tegra_edid_get_monspecs: EDID has no valid modes
[ 3323.706802] hpd: switching from state 2 (Check EDID) to state 2 (Check EDID)
[ 3323.713898] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 3323.714132] tegradc 15200000.nvdisplay: unblank
[ 3323.714149] tegradc 15210000.nvdisplay: blank - powerdown
[ 3323.714158] tegradc 15220000.nvdisplay: blank - powerdown
[ 3323.718450] tegra_edid_get_monspecs: no modes in EDID base block
[ 3323.727035] tegra_edid_get_monspecs: EDID has no valid modes
[ 3323.727178] hpd: switching from state 2 (Check EDID) to state 2 (Check EDID)
[ 3323.733911] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 3323.738659] tegra_edid_get_monspecs: no modes in EDID base block
[ 3323.747276] tegra_edid_get_monspecs: EDID has no valid modes
[ 3323.747441] hpd: switching from state 2 (Check EDID) to state 2 (Check EDID)
[ 3323.753893] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 3323.758652] tegra_edid_get_monspecs: no modes in EDID base block
[ 3323.766925] tegra_edid_get_monspecs: EDID has no valid modes
[ 3323.767138] hpd: EDID read failed 5 times. Giving up.
[ 3323.767151] tegradc 15210000.nvdisplay: blank - powerdown
[ 3323.767188] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 3323.767192] Extcon DP: HPD disabled
[ 3323.767196] hpd: hpd_switch 0
[ 3323.767200] hpd: switching from state 2 (Check EDID) to state 3 (Disabled)
[ 3323.771869] tegradc 15200000.nvdisplay: unblank
[ 3323.771885] tegradc 15210000.nvdisplay: blank - powerdown
[ 3323.771895] tegradc 15220000.nvdisplay: blank - powerdown
i find that the same screen connect to windows 10 notebook typeC is ok,so
what is wrong with jatson xavier?
I know Iam a noob and any help would be apprecieated.
