Jetson Xavier Developer Kit Power Supply
Hi all,
I lost the supplied power adapter with AGX Xavier Developer Kit. So I want to use another adapter to supply developer kit.
Is 12V - 1.5A DC adapter available to supply Xavier Developer Kit ?
Can you give any adapter advices ?
Thanks for all !
The power supply is rated 9v - 20v, the power consumption is about 10w - 30w, you can choose adapter accordingly.
Thanks for your reply.
Is the following adapter compatible with dev kit ?
https://urun.n11.com/adaptor-ve-sarj-cihazi/asus-toshiba-acer-casper-19v-342a-5525-65w-laptop-adaptor-P314985885
You can try that since its output seems OK.
But the connector also needs to fit, right? Can anyone confirm that particular supply worked?
Put in an other way, would the 5.5*2.5 MM connector work for the Jetson?
confirmed here “It’s a 2.5mm x 5.5mm barrel connector”: Portable Power Supply - #11 by snarky
The DC connector on board is 2DC-G213-B73F, Singatron Enterprise Co., Ltd. (USA)
