If in the unfortunate event that AGX Xavier’s AC Adapter is dead, are there readily available power supply’s available on sites like Amazon that would be able to serve as a suitable replacement (as an example)?
Hi asrocki, the barrel jack power supply is a LiteOn NSW26604 (65W, 19VDC). You may need to contact the manufacturer to find a suitable distributor.
Note that you can also use a USB-C Power Delivery adapter, which may be easier to obtain. See the Supported Components List for USB-C Power Delivery adapters officially validated against the Jetson AGX Xavier Developer Kit, including these:
Another USB-C Power Delivery adapter that should work is this Dell LA90PM170 USB-C power brick.
Great, glad it is compatible with Apple USB-C Power adapters.
Is any other 65W 19V DC laptop adapter compatible with AGX Xavier Developer Kit?
Hi @goksungur, please refer to the Jetson AGX Xavier Supported Component List:
https://developer.nvidia.com/embedded/dlc/jetson-agx-xavier-series-supported-components-list
I checked this document. But the recommended products are not available anymore. So I have to find another options.
I found the following product. Can I use it to provide power supply for dev KİT ?
We haven’t tried that particular adapter, but it looks like the 2.5x5.5mm dimensions of the power jack match. The Jetson AGX Xavier uses Singatron 2DC-G213-B73F DC power jack.
@dusty_nv
can we also use some of these USB-C power sources with Jetson Xavier NX? with some USB-C to jack adapter ? somehow?
I don’t believe so, or at least it hasn’t been tested before. The USB-C power-delivery adapters often have additional load-detection circuitry which I’m not sure a simple converter would work with.
