I am using a projector as a screen. Due to structural reasons, it is mounted upside down. I can use the display settings on the xavier to rotate it back 180 degrees. Before rotation everything is fine, after rotation there is a slight lag to everything. In particular typing on the keyboard sometimes takes a second to catch up. Ridiculously obnoxious. The web browser will also flash artifacts randomly, almost like screen tearing.
Can you share more information than the symptom?
Which jetapck release are you using?
Could you make a video to show us what is the exact error you see on the screen?
