I have a USB3.0 camera which can supply upto 60fps @ 1080p resolution. Just capturing the image and showing it on the display without any processing, seems causing more than 140ms delay. Below are three different code samples I tried, one of which is using the Jetson Inference tools, Couldnt have any success decreasing the latency. Any suggestions is much appreciated.
import cv2
cap = cv2.VideoCapture(0) cap.set(cv2.CAP_PROP_BUFFERSIZE, 1) while True: ret_val1, img1 = cap.read() cv2.imshow('Org', img1) if cv2.waitKey(1)==ord('q'): break cap.release() cv2.destroyAllWindows()
import cv2
cap = cv2.VideoCapture("nvv4l2camerasrc device=/dev/video1 cap-buffers = 2 !
video/x-raw(memory:NVMM),width=1280,height=720,framerate=30/1 !
nvvidconv !
video/x-raw, format=(string)BGRx ! videoconvert !
video/x-raw,format=BGR !
appsink sync=0 ")while True:
cv2.imshow(‘Org’, img1)if cv2.waitKey(1)==ord(‘q’):
breakcap.release()
import jetson.utils
cam=jetson.utils.gstCamera(1280,720,‘/dev/video0’)
disp = jetson.utils.glDisplay()
font = jetson.utils.cudaFont()while disp.IsOpen():
frame, width, height = cam.CaptureRGBA()
disp.RenderOnce(frame,width,height)cam.release()
