Hi
I am designing a custom board based on Jetson Xavier NX Module. I found that no audio codec was used in the development board but for my application I need it. In the design guide, I found part number ALC5639 that was recommended to use but no information was available for this IC on the internet.
My question is may I use any other IC instead of this that is I2S based or Xavier support only this ALC5639? I am planning to use TI’s TLV320AIC3106IRGZT. Will it work with the Xavier NX module or will I face any driver issues?
Regards,
Ather
You can use other codec, but need to handle the driver by yourself. The OEM DG has given the hardware design example and requests for a codec.
