I have been using the device for a week now and have rebooted several times without any problem. Last time I rebooted the device, it never booted again.
When I connect the power to the device, the power LED turns on, however, the screen is blank as if the device never boots. I have tried both HDMI and DisplayPort.
I believe the following ports are not working:
HDMI
My monitor does not detect any signal. -
DisplayPort
USB3.0 (all 4 of them)
I have a device that turns a LED ON whenever it was connected to any of the Jetson’s 4 USB ports. Now, this device’s LED does NOT turn on when connected to any of them. -
Ethernet
My router configuration site does not show the device even if it is connected directly to the router with the ethernet cable. Other devices do show up when connected with the cable. -
Micro USB
My pc does not recognize the device when it is connected.
– I’m in Ubuntu20.04
– The commandlsusblists all connected devices but NOT the Jetson
– I have been trying to debug using the serial console to determine what is wrong, but since my pc does not recognize the device I cannot read from it
Ports that seem to be working:
- CAM0 and CAM1
I have a camera module that has an LED that turns on when connected. This LED turns on as expected when connected to any of these ports.
I flashed a new SD card with JetPack4.5 but the device remains in the same state as described above.
