Jetson NX does not work
I connected power and HDMI cable to my jetson nx and I could not see anything on the screen. I removed the SD card from jetson and connected the power again and I could not see anything. Then I did everything according to this tutorial “Jetson Nano - Serial Console - YouTube”. I powered it and opened debugging console through UART. I connected USB to tty adapter to RX TX pins of 12 debugging pins. By opening the serial port in another jetson I received this.
What did you receive?
And i cannot type anything to the terminal.
please set up another x86 ubuntu host and flash your NX with sdkmanager.
No other method to recover.
